Question regarding Cisco 1400 Bridge
manjesin Sun, 01/27/2008 - 07:23
You can use bridge calculation utility provided on .. to calculate what would be the signal strength .. by providing the information about ..
*type of antenna u r using
* Distance between the device
* Other requested information
Here is a link
Incase, if you are not able open ..
Open ..
Search with keyword "Bridge calculation" .. open link for Br1400
Hope this will help ..
Please rate .. if you find useful so that other can also take benefit of this forum ..
manjesin Sun, 01/27/2008 - 07:25
Just add on above lines .. i missed it.. wireless performance depends on signal strength ..
If u get good signal strength then performance will be good ..
low signal -- slow performance ..
Thanks again
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
