rdp access
Jan 25th, 2008
i have a pix 506e at home and i would like to remote desktop to one of my laptops at home from work...
how do i open port 3389 to the E1505 latop on my network at home.
Current config on the pix
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 10.9.2.202 E1505
pager lines 500
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 10.9.2.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.9.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 10.9.2.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.9.2.200-10.9.2.210 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 200
Cryptochecksum:xxx
: end
Overall Rating: 5 (2 ratings)
Patrick Iseli Fri, 01/25/2008 - 16:47
  • Gold, 750 points or more
example:
access-list outside_access_in permit tcp any host PublicIP eq 3389
# This will allow any host to RDP into RDPServer
static (inside,outside) tcp PublicIP 3389 LocalIP 3389 netmask 255.255.255.255 0 0
#Port Redirect tcp port 3389 RDP to LocalIP
access-group outside_access_in in interface outside
# Apply access-list to interface
sincerely
Patrick
srue Sat, 01/26/2008 - 11:00
  • Blue, 1500 points or more
you need to use the 'interface' keyword, instead of PublicIP.
Danny Guillory Jr Sat, 01/26/2008 - 11:35
so the command i need to run is:
access-list outside_access_in permit tcp any host interface eq 3389
Is this correct?
srue Sat, 01/26/2008 - 11:37
yes...and change it in your static statement also.
Danny Guillory Jr Sat, 01/26/2008 - 11:51
here is my config. i don;t think there is a static statement in there. My IP address is dynamic from my ISP
PIX Version 6.3(3)
enable password xxx
passwd xxx
names
pager lines 300
mtu outside 1500
mtu inside 1500
pdm location 0.0.0.0 255.255.255.0 outside
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd address 10.9.2.200-10.9.2.250 inside
dhcpd lease 3600
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
: end
srue Sat, 01/26/2008 - 12:00
access-list outside_acl permit tcp any interface eq 3389
access-group outside_acl in interface outside
static (inside,outside) tcp interface 3389 10.9.2.100 3389
that assumes 10.9.2.100 is your pc on the inside you want to rdp to.
Danny Guillory Jr Sat, 01/26/2008 - 12:12
is there a way to show computer names and ip addresses that the pix has given out.
Danny Guillory Jr Sat, 01/26/2008 - 14:15
pixfirewall(config)# access-list outside_acl permit tcp any interface eq 3389
interface does not exist
Usage: [no] access-list compiled
[no] access-list deny-flow-max
[no] access-list alert-interval
[no] access-list [line ] remark
[no] access-list [line ] deny|permit
|object-group
| interface | object-group
[ [] | object-group ]
[log [disable|default] | [] [interval ]]
[no] access-list [line ] deny|permit icmp
[ | object-group ]
Restricted ACLs for route-map use:
[no] access-list deny|permit {any | | host }
srue Sun, 01/27/2008 - 04:59
woops, left out part:
access-list outside_acl permit tcp any interface outside eq 3389
r00KEY73k Thu, 02/14/2008 - 23:16
My customers using rdp cannot access remote pc through my router since I config'd basic acls on router: acl 10 = deny internal network in; acl 11 = permit snmp server; acl 12 permit ssh access. Also, when I applied acl 12 to egress int, snmp polls, blocked. ACL samples follow:
acl 10 deny 10.10.1.0 0.0.0.255 log, acl 10 permit any log; acl 10 applied at ingress port; acl 11 permit 10.10.2.2 log; snmp-server host 10.10.2.2; acl 12 permit remarks ssh access; acl 12 permit 10.10.3.1 log; acl 12 deny any log. Will any of acl's deny rdp on the router? Will config of above sample acl allow rdp traffic? Appreciate your assistance. Thank-you, r00KEY73k
