Thin-Client SSL VPN (WebVPN) with Single Sign-on on ASA with ASDM
Jan 25th, 2008
Hi all,
When I configured Thin-Client SSL VPN(WebVPN) on ASA 5510, I encountered some probblem, please everyone give me a hand, thx.
Situation:
I configured Thin-Client SSL VPN(WebVPN) on my ASA 5510 successfully, I didn't want to create per VPN useraccount for my AD users, I want to ask how to integrated with Thin-Client SSL VPN(WebVPN) with Single Sign-on.
borisloong Sun, 02/03/2008 - 23:53
thanks for your information, I have configured it via Thin SSL WebVPN with Kerebos (authentication) and LDAP (authorization) successfully, AD user can login to ASA firewall and connect to his/her ower share folder, I make you misunderstand, sorry. I want to configure AD user can log in our ASA firewall. thanks
dcarlton Fri, 02/01/2008 - 03:42
What type of single sign are you doing? Are you using windows explorer to windows servers?
For most single sign on to work you need to have the destination URL in your 'local intranet zone for Internet Explorer. This means your Internet URL needs to be added to the clients PC in the local security zone.
borisloong Sun, 02/03/2008 - 23:48
I have configured it via Thin SSL WebVPN with Kerebos (authentication) and LDAP (authorization) successfully, AD user can login to ASA and connect to their share folder via MacOSX PC, thanks for your information.
