Any reason for this strange behaviour..?
Jan 25th, 2008
Hi All,
SiteA & SiteB with Vpn tunnel. SiteA :ASA5510 and SiteB:2811 router with VPN s/w.
At siteB , we moved the DSL connection to Cable connection and changed the all the necessary IPs and ACLs and also peer IP information on SiteA.
The tunnel never came up at that time and syslog popped up with QM FSM error (P2 struct&04e40918,mess id 0xc85b22b2)!
Surprisingly, without doing any further t-shoot Tunnel came up by itself after couple of hours.The onyl reason Iam tinking at this time for this behaviour is, during the tunnel lifetime renewal/restart(86400),it is established with new peer.
Can somebody suggest any other reason for this..?
Thanks in advance.
MS
Overall Rating: 4 (1 ratings)
ajagadee Fri, 01/25/2008 - 21:47
MS,
Did you clear the ISAKMP and IPSEC SA's on the ASA5510 for the IPSEC Tunnel to SiteA. It looks like while you were moving cable and reconfiguring the router, the ASA was still thinking that the IPSEC SA's were active.
The error (QM FSM) means it received a packet out of order. For instance you were trying
to establish a tunnel, a packet for step five and a packet for step six were
receive out of order. (or one wasn't received at all.) This could be caused by something
like the packets taking different paths.
It seems that after the tunnel went down, it just needed to clear the SA's on both sides
of the tunnel, in order to bring the tunnel up again.
Below is an URL with some IP Security Troubleshooting Steps. I hope you find it useful.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a00800949c5.shtml#qms
Arul
** Please rate all helpful posts **
mvsheik123 Sat, 01/26/2008 - 06:03
Hi Arul,
Good point. Thank you. I did not clear any SAs before moved to Cable. Also, I used 'no tunnel-group x.x.x.x ip-sec attributes' on ASA at SITEA to remove existing SITEB info and then added the new IP peer info. So that also might have caused the issue (clear .... - may be preferred command). Thank you for the reply.
regards
Mehboob
Bikramjit Majumdar Sat, 01/26/2008 - 10:24
Hi, Whenever you change the ip addressing scheme in you network, it is better to follow the steps mentioned below:
1.If possible remove the crypto map from the interface of both the devices.
2. Clear all the phase-1 and phase-2 settings for both firewall and router. The commands will be:
For Firewall:
clear crypto isakmp sa
clear crypto ipsec sa
For router:
FOR PHASE 1:
clear crypto isakmp
FOR PHASE 2:
clear crypto sa peer
Note: In the router, If you do:
sh crypto isakmp sa, it will give you the following columns:
dst src state conn-id slot status
So, whatever be the conn-id for a specific tunnel you have to delete that
3. After that reapply the crypto map's on both the devices and then try to initiate the interesting traffic across vpn and check the status.
Reason:
Check link:
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/ike.html#wp1059730
The 2nd paragraph states: "Binding a crypto map to an interface also initializes run-time data structures, such as the security association database and the security policy database. If the crypto map is modified in any way, reapplying the crypto map to the interface resynchronizes the various run-time data structures with the crypto map configuration. In addition, any existing connections are torn down and reestablished after the new crypto map is triggered.
Hope that helps!
Bikramjit
