CCM Trace
Jan 25th, 2008
I'm receiving the following message in the CCM traces I left out most of it but the interesting part is the deleteThisDevice and the propagation.
What is this telling me?
CCM|DeviceManager::deleteThisDevice - Name=64986:TEST PARTITION found in local tables and Propagation is needed
The bottom line is that we are having issue with dialing certain partitions.
Ayodeji Okanlawon Sat, 01/26/2008 - 05:04
  • Cisco Designated VIP,
    2017 IP Telephony
what exactly is the problem you are having...
This inofrmation usually comes when a device unregisters with CCM so the device manager (which handles all device registration and all device connection to CCM) deletes the device registration from CCM.
So you need to send the full CCM trace and a detailed explanation of the problem you are having.
aod@capgroup.com Sat, 01/26/2008 - 05:48
We have two partitions. A "test" partition and a "production" internal partition. We had a slew of phones that we put in the test partition because we didn't want users to reach that DN. Now, we are moving those users to the "production" internal partition. However, some DN can't reach other DNs that are in the same parition. It's as if CCM isn't acknowledging the change on some phones from test partition to internal partition.
Ayodeji Okanlawon Sat, 01/26/2008 - 07:20
    2017 IP Telephony
It looks as if you have not put the order of partitions correctly.
Makesure that the new partition is the first in the list of partitions and try again.
Rob Huffman Sat, 01/26/2008 - 08:22
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Alex,
I have seen a bug that does effect these partition changes exactly this way. Can you please provide your CCM Version.
Rob
Jaime Valencia Wed, 01/30/2008 - 10:13
  • Cisco Employee,
  • Hall of Fame,
    2011
that message means the DM is out of sync, there are some bugs related to that
CSCse43391
DM table out of sync..Device manager handling of linkOOS
you would need to post the whole trace to verify at which point it's failing
