Upgrade IOS on the Switch
alsayed
Dear NetPro!
i have the following IOS:cat4000-i9s-mz.121-19.EW1.bin on my 4507R With 2 SUP-WS-X4515 now i need to upgrade to New IOS wich met my Chassis.wich is IOS(full name) Switable and plz provide a documents for the Upgrade
many Thanks
22 Replies 22
ankbhasi
Hi Ali,
I hope this link helps you
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/19ew/configuration/guide/RPR.html#wp1104060
Please come back if you have any doubts.
Ankur
Ankur My Freind
10xs for ur Help.what about the Full Name of the IOS Needed?
10xs
Hi Ali,
Do you know the main release you want to upgrade so that I can update you with the full name or you want to upgrade to the latest code which can be supported on your supervisor and you want us to update you with the full name?
Ankur
Ankur Ankur My Freind!
i need the latest code which support the SSO Features not the old one wich's RPR
10XS
Hi Ali,
You can use Feature Navigator to select the feature set which you want.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Once you open this link, click on serach by platform and then select cat4500 sup 4 form the drop down and then you can select the major release and which feature set you want. All features supported in that particular release will be listed.
Ankur
Hi Ali,
The code what you are running currently is very old code which goes in 12.1 train. Also the feature set which you are running currently is BASIC L3.
Ankur
Edison what do you mean by kitchen sink ?
Hi Edison,
Yes you are right.
Ankur
Ali,
SSO is supported in Release 12.2(20)EWA and later releases.
Any current IOS from cisco.com for the 4500, supports SSO.
I recommend downloading cat4000-i9s-mz.122-25.EWA11.bin
10XS FOR ALL UR REPLYs
What about this IOS?
c4500-jk9s-mz.122-40.bin
thanks for ur Help
Ali,
cat4000-i9s-mz.122-25.EWA11.bin is more stable. You've not purchased a k9 feature set you legally, you aren't supposed to download such code.
BTW, cat4500-ipbasek9-mz.122-40.SG.bin requires a bigger flash, can you post a show version from your current switch ?
__
Edison.
