Wireless LAN controller 4402
Answered Question
Jan 26th, 2008
Is it possible to config only 1 GB connection to 4402 LAN controller. Or must I use both Gb connectors ?
Because I have only 1 Gb port free on my switch.
Correct Answer by ankbhasi about 9 years 2 months ago
Hi Rene,
You can very well use only one gig port to connect to the switch. 2 ports can be used if you want to have por tchannel on switch and you want your controller to work with LAG.
But you can simply connect 1 port on switch to the controller and while configuring manamenet and ap-manager interface bind them to one physical port whichever you are using.
Ankur
*Pls rate all helpfull post
Overall Rating: 4 (1 ratings)
Correct Answer
ankbhasi Sat, 01/26/2008 - 11:11
  • Cisco Employee,
Hi Rene,
Ankur
