Factory default config for cisco 871w router
Jan 26th, 2008
I blew away the factory config that came with my 871w router. now i can not use my sdm disk because it is looking for the 10.10.10.1 ip scheme. can anyone please provide this config so i can start using my router?
ebreniz Thu, 01/31/2008 - 12:23
  • Silver, 250 points or more
For the fresh configuration of the router follow the below steps:
Sample procedure is as follows:
Router#config t
Router(config)#config-reg 0x2142
Router(config)#end
Router#show version (check the last line of the output)
Router#reload
When the router reloads, please type this command:
Router#write memory
Router#config t
Router(config)#config-reg 0x2102
Router(config)#end
Router#reload
At this moment, your router is at Factory default and ready to set any configuration.
Or another way is:
Router#write erase
or
Router#erase nvram:
paolo bevilacqua Thu, 01/31/2008 - 15:13
  • Hall of Fame,
    Founding Member
On the 8xx, two more ways:
copy flash:c871-default-sdm.cfg startup-config
reload
(I made up the exact flash filename, do dir and you will see it)
or press the reset button just after turning on.
