Remote access VPN using ASA 5510
Jan 27th, 2008
(diagram attached).I configured cisco ASA 5510 for remote access vpn. User can access server from internet. It is working well. When any user tried through CDMA 2000 1x technology (internet), he is able to get connected but can not telnet or remote desktop. Do you think any configuration needed for CDMA in ASA or not? Can you give me the solution?
mizan_rahmanbd1 Sun, 01/27/2008 - 01:19
Diagram shows ASA5510 and connected server. User can access server through internet. But cannot using CDMA 2000 1x technology.
m.sir Mon, 01/28/2008 - 01:05
Sounds like MTU issue - Can you ping from the host to the server???
You can try ajust MTU settings on outside interface
ASA(config)# mtu Outside 1300
Let us know the result
M.
hope that helps rate if it does
mizan_rahmanbd1 Wed, 01/30/2008 - 04:04
No I cannot ping the server when I connected through CDMA.
But, in GSM technology and Dial-up internet, it is possible to ping, remote desktop and telnet also.
MTU is running with 1500
