RTMT on CCM 4.2 Java error
Answered Question
Jan 27th, 2008
When I start the RTMT on the servere or on a client connection to the server i get a java.util.missingresourceexeption error.
can anyone help me with this problem how to get i solved ?
Best regards
Soren Knudsen
Correct Answer by Rob Huffman about 9 years 2 months ago
Hi Soren,
You may be hitting this bug;
CSCse78153 Bug Details
RTMT does not work on winos 2000.4.3a or 4.3SR1
Symptom:
RTMT can not work after upgrading to winos 2000.4.3a sr 4.3SR1 with following
error.
java.util.MissingResourceException: Can't find bundle for base
name org.apache.xerces.msg.XMLMessages, locale ja_JP
Conditions:
OS upgraded to 2000.4.3, 2000.4.3a, or 2000.4.3aSR1. This documents the need
for RTMT to function correctly when RemoveServerHeader=1 in urlscan.ini.
Workaround:
Change the value of RemoveServerHeader in urlscan.ini
(C:\Winnt\system32\inetsrv\URLscan\urlscan.ini) from 1 to 0 and reboot the server.
OS 2000.4.3asr2 sets RemoveServerHeader to 1 to workaround this issue until
RTMT can correct behavior.
After upgrade to 4.2(3) 3.3(5)ES49 4.0(2a)ES88 4.1(3)ES72 4.2(1)ES21
RemoveServerHeader can be set back to 1.
1st Found-In
4.1(3)
4.1(3)SR3
4.2(1)
Fixed-In
4.2(2.116)
4.2(3.1)
3.3(5)ES49
4.0(2a)ES88
4.1(3)ES72
4.2(1)ES21
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Sun, 01/27/2008 - 08:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Soren,
Symptom:
error.
Conditions:
Workaround:
1st Found-In
4.1(3)
4.1(3)SR3
4.2(1)
Fixed-In
4.2(2.116)
4.2(3.1)
3.3(5)ES49
4.0(2a)ES88
4.1(3)ES72
4.2(1)ES21
Hope this helps!
Rob
Rob Huffman Fri, 02/01/2008 - 05:44
  • Hall of Fame,
    Founding Member
Hi Soren,
You are most welcome! Always some strange errors aren't there?
Take care,
Rob
