What is the VLAN range on a 2960 switch.
Jan 27th, 2008
Hi, I require to trunk VLANs over 1001 to a new cisco 2690 switch. My concern here is that these switches only support VLANs in the range of 1-1001. Could anyone please confirm if this is the case?
The part number of the switch is WS-C2960-24TT-L
Thanks in advance for any help.
ankbhasi Sun, 01/27/2008 - 06:32
  • Cisco Employee,
Hi Daniel,
This link should clear your doubts
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12244se/scg1/swvlan.htm#wp1298058
Allowed vlans on trunk section
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12244se/scg1/swvlan.htm#wp1150302
Please come back if you have any more doubts on the same.
Ankur
*Pls rate all helpfull post
CSCO10576352 Sun, 01/27/2008 - 06:37
Thanks for the reply, looks like as long as the switc is in vtp transparent mode vlans 1-4096 will be supported. Thanks.
shrikar.dange Sun, 01/27/2008 - 20:16
  • Bronze, 100 points or more
hi,
Yes you are right.If you want to use extended vlans in your 2960 you have to use VTP trnsperent mode.Because extended vlans are not stored in the vlab.dat file and can not be advertised in VTP advertisements.
AFAIK 2960 supports (in transperent mode) 1-4094 vlans but maximum no. vlans configured is 255. 0& 4095 are reserved for system use.
HTH,
regards,
shri :)
