ajagadee Sun, 01/27/2008 - 14:44
  • Cisco Employee,
7.0(7), the latest in 7.0 train for the ASA is not deferred. Also, note that 7.0(7) is a GD Code.
Is there a specific version in 7.0 that you would like to know is deferred or not. There was a new security vulnerability released for ASA and I dont see 7.0 has an affected version.
http://www.cisco.com/en/US/products/products_security_advisory09186a008093942e.shtml
I hope it helps.
Arul
** Please rate if it helps **
nomair_83 Sun, 01/27/2008 - 22:06
  • Bronze, 100 points or more
hi arul,
I have 7.0(6).
Thanx
ajagadee Sun, 01/27/2008 - 22:28
  • Cisco Employee,
Thanks!
7.0(6) is not deferred. Is there a specific reason for you asking this. I would check the release notes for 7.0(6) to make sure that your environment is not affected by any of the caveats listed in the open section. Also, if your company has a standard of using GD Codes over ED Codes, then you may want to look at 7.0(7) which is GD.
Arul
** Please rate all helpful posts **
ajagadee Sun, 01/27/2008 - 23:57
  • Cisco Employee,
Thanks for the rating! :-)
Arul
nomair_83 Sat, 02/02/2008 - 12:34
Hi arul,
If we have 3 servers like domain controller,application server,exchange server
so what is the best practice,
should we place only exchange server in dmz or all 3 servers,
m.sir Sat, 02/02/2008 - 12:48
  • Gold, 750 points or more
Main purpose of DMZs is separate from inside network servers that must be accessible from outside..DMZ is network that sits between a trusted internal network, such as a corporate private LAN, and an untrusted external network, such as the public Internet.
So if its no reason for access to DC from outside I should keep DC inside... same for application server.. If you exchange provide mail services for remote users (IMAP, web access) - its exactly reason why place the server to the DMZ
M.
Hope that helps rate if it does
nomair_83 Sat, 02/02/2008 - 21:58
Thanx for confirming my concepts,
