01-27-2008 10:06 AM - edited 02-21-2020 03:30 PM
I have tried to install the Cisco VPN client version 5.0.02.0090 and every time I try to install it on my desktop (Windows XP SP2) I get the error InstallDNE any help in resolving this error would be greatly appreciated.
01-27-2008 11:10 AM
I had the same problem and the following link solved this issue:
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=2242876&SiteID=1
Morten Haugan
Norway
01-27-2008 10:49 PM
Thanks for the information but even after cleaning everything out and trying to install the DNE upgrade I get the error "Unable to manage Deterministic Network Enhancer" So im still stuck
Adam Sebesta
01-30-2008 01:47 PM
Did you completely uninstall any other VPN client that may have been there before?
02-21-2008 10:47 AM
Thank you, Morton. Your response was very helpful. I was having a similar issue with a Windows XP machine. The DNE update did the trick.
Sincerely,
Michael
01-30-2008 05:30 PM
Hi Adam
Try uninstalling any previous VPN client software via following tool
http://www.softpedia.com/get/Security/Secure-cleaning/Windows-Installer-CleanUp-Utility.shtml
Then run following tool and restart your PC.
http://www.snapfiles.com/get/winsockxpfix.html
Now try installing again.
