01-27-2008 12:01 PM - edited 03-18-2019 08:23 PM
Well after battling DMA all weekend! And starting off with 400+ errors I'm down to 1. And need some help!
The error is logged in the datavalidation.log.
Here it is:
Table: CredentialPolicy Number of records: 1
Row: 1 SQL error: 1002
Error message: Cannot modify or delete the installed Default Credential Policy.
pkid 9454babf-48d0-4e16-9b80-2d0da4b38750 NOT MODIFIABLE
DisplayName Default Credential Policy
HackResetTime 30
LockoutDuration 30
MaxDays 0
MaxHacks 0
MinDuration 0
MinLength 1
PrevCredCount 0
TrivialCredChecking false
ExpiryWarningDays 0
IsStandard true NOT MODIFIABLE
MaxInactiveDays 0
Thanks Guys!
Solved! Go to Solution.
01-28-2008 11:44 AM
seems you're hitting
CSCsh38822
Externally found moderate defect: Resolved (R)
DMA Validation Err on Default Credential Policy rec in CredentialPolicy
01-28-2008 11:44 AM
CSCsh38822
