ssh to pix
Answered Question
Jan 27th, 2008
i am trying to ssh to my pix from a outside connection. I am using a verizon wireless card and my ip is changing all the time.
can some please tell me what to add to my configuration so that i can accomplis this!
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol icmp error
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 10.9.2.200 E1505
name 10.9.2.204 slingmedia
name 10.9.2.202 playstation3
access-list outside_acl permit tcp any interface outside eq 3389
access-list outside_acl permit tcp any interface outside eq 5001
pager lines 300
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 10.9.2.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface 3389 E1505 3389 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 5001 slingmedia 5001 netmask 255.255.255.255 0 0
access-group outside_acl in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.9.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 10.9.2.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd address E1505-10.9.2.250 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 200
Cryptochecksum:xxx
: end
Correct Answer by manjesin about 9 years 5 months ago
Command to regenerate RSA key on 6.3 software is
ca generate rsa key 1024
ca save all
Notice,outside interface is configured dhcp client .. make sure outside interface is not diferent then ip address u r trying ssh ..
Overall Rating: 5 (1 ratings)
ajagadee Sun, 01/27/2008 - 23:23
  • Cisco Employee,
Have you generated the RSA Key. "crypto key generate rsa general modulus 1024" for SSH to work.
Also, since you have "SSH 0.0.0.0 0.0.0.0 outside" configured on the Pix, pretty much anyone from the outside world should be be able to SSH into the Pix and ofcourse they need to know the username/password.
Arul
** Please rate all helpful posts **
srue Mon, 01/28/2008 - 05:33
  • Blue, 1500 points or more
your username will be 'pix' and your password will be whatever your normal password is.
Correct Answer
manjesin Tue, 01/29/2008 - 16:46
ca save all
