2port 2nd gen Multiflex trunk voice/wan int.T1/E1 Card with ATM
Answered Question
Jan 27th, 2008
Product#: VWIC2-2MFT-T1/E1
Can use this with ATM connection.
i cannot use the command "mode atm aim 0"
thanks
Wael
Correct Answer by Paolo Bevilacqua about 9 years 3 weeks ago
Hi, to add to the good advice from Chris, I will try be even more clear:
You need to buy a piece of hardware called AIM-ATM, open the router, and fit it inside.
Without it, you cannot do ATM and the commands are not recognized.
As a recognition to those giving answers, please rate useful posts with the scrollbox below!
Correct Answer by chris_tan about 9 years 3 weeks ago
If you can see below output from "sh ver". Which mean you have correct AIM-ATM module installed. Else pls make sure you purchase it and install properly.
Processor board ID FHK1116F3CN
2 Gigabit Ethernet interfaces
1 ATM interface
2 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
1 ATM/Voice AIM
Also, if you can see it. Please add "mode atm aim 0" under controller e1 0/0/0
controller E1 0/0/0
mode atm aim 0
Hope it help.
Thanks.
Rgds,
Christopher
Overall Rating: 4 (3 ratings)
Paolo Bevilacqua Mon, 01/28/2008 - 02:50
Do you have the AIM-ATM installed? Do "show diag" to check.
Paolo Bevilacqua Tue, 01/29/2008 - 01:40
Open the router and fit the module inside.
welaish77 Tue, 01/29/2008 - 01:44
i already did that but i cannot make it work on ATM.
i cannot issue the commands.
my question is does this module supports ATM connection.?
Correct Answer
chris_tan Tue, 01/29/2008 - 01:54
1 ATM interface
1 ATM/Voice AIM
controller E1 0/0/0
mode atm aim 0
Hope it help.
Thanks.
Rgds,
Christopher
Correct Answer
Paolo Bevilacqua Tue, 01/29/2008 - 02:02
welaish77 Tue, 01/29/2008 - 02:10
Thanks Bevilacqua and chris. That was my question The card that mentioned in the topic cannot act as ATM module.
i will buy ATM Module and try it.
i tried to do this it worked but i cannot add the command "mode atm aim 0" only "mode atm" without "aim 0"
card type e1 0/0/0:0
controller E1 0/0/0
mode atm
anyways thanks it seems this card is not compatible i will get ATM-AIM Module.
Wael
Paolo Bevilacqua Tue, 01/29/2008 - 02:26
Yes the card that you have can work in ATM mode but if you don't install the AIM-ATM, you cannot enter the ATM commands.
I've noticed that you haven't rated posts, would you consider doing so as an appreciation to those that are giving you free and good answers ?
