Lab equipment as per blueprint or ?
Jan 28th, 2008
Hello, everybody!
I have some 2810s, but blueprint says that 3725/3825 should be used. The question is: Can I use safely 2810s with the same IOS feature set instead of 3725/3825 ?
Thank you for your replies!
srue Mon, 01/28/2008 - 07:18
as long as the feature set and interface types and IOS versions are there, you will be OK.
