console problem
Jan 28th, 2008
Hi All,
I have a router 2501.
i am not able to connect it. when i connect the console cable, it doesnt show anything in hyper term. i had changed the cable and laptop but it still not accessible.
when i try to telnet it through pc, it gives following error msg,
no password set,
connection to host lost.
can anyone tell me what is the problem and how can it be rectified. is there any other way to access the router?
thanks in advance
rgs,
jack
Fraser Reid Mon, 01/28/2008 - 02:23
maybe you need to perform password recovery ?
Also check the Hyperterm settings with what Cisco says they should be.
jackthumar Mon, 01/28/2008 - 02:45
Hi Ivan,
Thanx for reply.
I had done it all. the hyper term settings are fine only.and i was able to access it till recently but not this time.
i also checked various combinations of hyperterm but to no use.
can anyone throw some more help?
rgs,
jack
jackthumar Mon, 01/28/2008 - 03:11
Hi Michael,
Thanks for reply.
i tried connecting it to the AUX port, but didnt work.
the conlose port in router looks fine from outside, is there any chances of damage(logicaly or physicaly)from inside?
rgs,
jack
