CPU performance on 1721 series router
Jan 28th, 2008
on one of my router cpu utilization is getting higher and due to this application access is getting effected.
I am sending the utilization details.
Pls suggest is there any thing that i can do by myself or need to raise a call to the vendor
regds
royalblues Mon, 01/28/2008 - 03:11
can you post the sh process cpu when you have high utilization
Narayan
Joseph W. Doherty Mon, 01/28/2008 - 05:13
You might want to look at: http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
Also, if you can post your show proc cpu when its very high, other suggestions might be provided.
PS:
Do note, that routers have a finite capacity, so sometimes the traffic load require a more powerful box.
From the show cpu process listing you provided, looks like your cpu hits are bursty and I don't see any software process with a look term high utilization.
