UCCX 5.0 Outbound Dialer CAD workflow questions
Jan 28th, 2008
Does anyone knows that if the UCCX 5.0 outbound feature also workflow actions? so i can call an URL / run execute when the call is answer / ring / drop.
I have tried to use the default rule and define an action for call a program.
It works with inbound when i drop the call but i didn't works in outbound situation.
Overall Rating: 5 (1 ratings)
rbua Mon, 01/28/2008 - 04:47
Hi Alex,
this is a documented behaviour for the current product and feature availability, see section 2-16 of the SRND:
Deployment Guidelines
The following guidelines should be followed when deploying Outbound:
- cut -
• All macros and automatically invoked workflows configured for the agent desktop are disabled during an outbound call.
- cut -
lee.alex Mon, 01/28/2008 - 08:16
Thanks Riccardo.
I think this already answer my questions.
But do you know is there any other way i can do for achieving similar functions like the workflow actions?
rbua Mon, 01/28/2008 - 08:30
Hi Alex,
I am afraid the correct answer will be not in the current Release.
