SSH feature support
Answered Question
Jan 28th, 2008
How can i check that a particular IOS version support SSH features or not
thanks
Correct Answer by royalblues about 8 years 11 months ago
SSH requires Crypto software and hence the bestr way to check is whether you have the letter "K9" in the IOS
flash:c3825-advipservicesk9-mz.124-3g.bin
Another thing would be to check whether you are able to execute the following command
crypto key generate rsa
And you can always use the feature navigator to check these
www.cisco.com/go/fn
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Mon, 01/28/2008 - 04:06
www.cisco.com/go/fn
Narayan
