IPS4240 wont boot
slug420
I am getting the following when trying to boot a new 4240:
Mounting proc filesystem: [ OK ]
Configuring kernel parameters: [ OK ]
Setting clock (localtime): Mon Jan 28 04:19:37 UTC 2008 [ OK ]
Activating swap partitions: [ OK ]
Setting hostname sensor: [ OK ]
Your system appears to have shut down uncleanly
Not forcing file system integrity check due to default setting
Checking root filesystem
/dev/hda4 contains a file system with errors, check forced.
/dev/hda4: Inode 34700 has illegal block(s). [/sbin/fsck.ext2 (1) -- /] fsck.ex
t2 -a /dev/hda4
/dev/hda4: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
[FAILED]
*** An error occurred during the file system check.
*** Dropping you to a shell; the system will reboot
*** when you leave the shell.
Give root password for maintenance
(or type Control-D for normal startup):
my questions:
1. How do I resolve this?
2. Is there a default root password for maintenance? I dont remember setting any passwords on this the one previous time I booted it up.
3. If the solution is re-imaging the sensor how do I do that and where do I get the image from?
mhellman
Level 7
Level 7
I would recommend just re-imaging. See this link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_installation_guide_chapter09186a0080757a93.html#wp1030825
You download the images from here(you will need a valid contract for the sensor to access):
http://www.cisco.com/cgi-bin/tablebuild.pl/ips6-system
