Configuration migration from PIX to ASA
Jan 28th, 2008
Dear collegues!
Could you help me with my question?
Can I migrate a configuration from PIX515 to ASA5510 in this cases?:
1) PIX OS ver 6 -> ASA OS ver 7
2) PIX OS ver 7 -> ASA OS ver 7
Is the process of configuation migration clear?
What issues could be with configuration migration from PIX to ASA?
Thanks a lot!
m.sir Mon, 01/28/2008 - 06:50
Here is a step-by-step guide to 6.x to 7.x migration:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807c3627.shtml#c3
Naturally - I would recommend saving a copy of your config and having a fallback plan in the event of any issues.
PIX 6.3 to PIX 7 is automated process
check this link
Regarding PIX 7 to ASA 7 you shouldnt have any issues - syntax and commands are pretty same s
If you need upgrade from pix 6.3 to ASA 7.0 i suggest upgdrade to PIX 7 and then move to ASA
M.
Hope that helps rate if it does
chitre_salil Mon, 01/28/2008 - 15:49
PIX OS version 6 to ASA OS ver 7 - As long as your config does not contain conduits there should not be any problem.
We had a similar migration recently and we had the complete config ready on the ASA first. We tested the basic access-lists and translations in a test environment before deploying it in production.
Salil
