Paolo Bevilacqua Mon, 01/28/2008 - 06:12
That is caused by a memory leak happening on both XJ and XW versions, I've experienced this also, but had not yet the strength to raise a case about.
Reload router and you will be able to configure the DP or ephone-dn.
Paolo Bevilacqua Wed, 01/30/2008 - 13:30
Hi, watch out if you are experiencing this.
I suspect the meory leak is more serious than I tought, as apparently has caused total failure of ISDN with "cannot expand chunk" error messages. Reboot fixed it, but I'm downgrading IOS as a precaution.
