2801 QoS on sHDSL card
Jan 28th, 2008
I can't find the answer on the web and I want to know if it is supported.
I have a 2801 with a sHDSL WAN card.
1) When I configure
class-map match-all IncATM
match input-interface ATM0/0/0
policy-map IncIF
class IncATM
set ip dscp af41
the dscp is not being modified, but it works fine on Eth interfaces.
2)I can't apply a shape policy on ATM interface (or sub-if).
Paolo Bevilacqua Mon, 01/28/2008 - 07:11
1. please do use match input-interface to sub-id, not main interface.
2. Which kind of shaping, why can't you attach ?
dfauluchi Tue, 01/29/2008 - 06:06
1) I've already tried that and didn't work. This is the config:
interface ATM0/0/0
bandwidth 4096
no ip address
load-interval 30
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
bandwidth 4096
ip address
atm route-bridged ip
pvc 0/35
vbr-rt 4096 4096 1
encapsulation aal5snap
2) When I try to attach this policy to the pvc I receive a message saying something like GTS is not available.
policy-map out1
class MC
bandwidth 300
shape 300
Paolo Bevilacqua Tue, 01/29/2008 - 06:18
which exact IOS are you using? If no need for 12.4 T features, please upgrade to 12.4(3j) and try again.
yavuz.ozdemir Thu, 01/31/2008 - 02:45
I'm facing a problem SHDSL, I have a 2811 and my controller is flapping UP-DOWN-UP-DOWN. Which is your config. for the controller DSL ? Here's my config.
controller DSL 0/0/0
mode atm
line-term cpe
line-mode auto
dsl-mode shdsl symmetric annex B
Have you an idea, why is not stable?
dfauluchi Fri, 02/01/2008 - 06:21
I really don't know much about it, but you must be sure to match the config to the other end.
I used a 4 wire config, connected to a DSLAM:
controller SHDSL 0/3/0
dsl-group 0 pairs 0, 1
shdsl 4-wire mode enhanced
shdsl annex B
shdsl rate auto
