Upgrade 3620 router with 2811 router
Answered Question
Jan 28th, 2008
I currently have in place a cisco 3620 Router with 4 t1 wic cards and 2 Fastethernet ports. We want to replace with somthing compareable. Can I use the wic cards from the 3620? If not What all do I need to have the same configuration
Correct Answer by Edison Ortiz about 9 years 5 months ago
Yes.
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Mon, 01/28/2008 - 07:13
  • Hall of Fame,
    Founding Member
Yes.
__
Edison.
dukeminus Mon, 01/28/2008 - 07:20
Thanks for confirming the use of my exesiting wic cards. Does this device have 2 Fastethernet ports?
royalblues Mon, 01/28/2008 - 07:27
  • Green, 3000 points or more
Yes it does have 2 FE ports
What T1 cards are you using btw?
Edison, I know that the ISR supports WIC-1DSU-T1-V2 cards but not sure whether they support the version1 WIC-1DSU-T1 module.
Can you confirm?
Narayan
Edison Ortiz Mon, 01/28/2008 - 08:12
  • Hall of Fame,
    Founding Member
It does not. Only v2 is supported. Good point.
__
Edison.
