Changing Cisco Switch
Answered Question
Jan 28th, 2008
i want to change the telnet password for cisco switches 2950 & 2970, what is the command please ?
Correct Answer by royalblues about 9 years 1 month ago
If you use line vty 0 15, the configs will be applied to all the vty ports
under global configuration use the command
"service password-encryption"
This will encrypt the password
Narayan
It just the number of terminal lines that are supported on the platform.
All new devices have 16 TTY ports while the old ones just had 5
Narayan
line vty 0 4
password
wr mem
Narayan
Overall Rating: 5 (4 ratings)
Correct Answer
royalblues Mon, 01/28/2008 - 07:20
  • Green, 3000 points or more
line vty 0 4
password
wr mem
Narayan
majdalani Mon, 01/28/2008 - 07:24
Hi Thanks,
whats the difference between :
line vty 0 4
and
line vty 0 15 ??
Correct Answer
royalblues Mon, 01/28/2008 - 07:29
Narayan
majdalani Mon, 01/28/2008 - 07:36
Hi Narayan,
so if i used any it wont be any difference !
royalblues Mon, 01/28/2008 - 07:38
The configurations will be applied to only those ports mentioned in the command
eg. if you have 16 vty lines and you configure
line vty 0 4
password
then the password wont be applied to the lines 5 to 15
Narayan
majdalani Mon, 01/28/2008 - 07:45
Hi thanks for your quick replies.
does this mean users will still be able to telnet the switch thru these lines ?
royalblues Mon, 01/28/2008 - 07:49
Yes..
It is always a best practice to apply these configurations on all the TTY ports
Narayan
majdalani Mon, 01/28/2008 - 07:56
WOW !!
u mean i will have to go :
line vty 0 1
line vty 0 2
line vty 0 16
2nd question please, i have applied : live vty 0 15
when i run the show run command, i can see the telnet password, how can i encrypt it , so that the person setting next to me does it read it in plain english ?
Correct Answer
royalblues Mon, 01/28/2008 - 08:00
Narayan
majdalani Mon, 01/28/2008 - 08:25
will this encrypt the enable password as well ?
Kevin Dorrell Mon, 01/28/2008 - 08:40
Yes it will, but you are probably already using an enable secret, which is already encrypted as standard, and much more securely.
Password encryption is pretty weak - there are loads of tools on the Internet to crack them in no time at all. If there is any possibility that someone gets hold of your config listings, you are better off defining a "secret" for each user rather than a "password". (Or even using an authentication server, but that will start getting more complicated and expensive.)
Encrypted passwords are tagged with a '7' in the config listing, and are weak. Secrets are tagged with a '5' and are quite a lot stronger.
Kevin Dorrell
Luxembourg
majdalani Mon, 01/28/2008 - 09:02
hi,
this is now my configuration :
line con 0
line vty 0 4
password mypass
login
line vty 5 15
password mypass
login
as u can see there are 2 lines line vty .
my boss configured the switches, when i asked him what did u insert as a commands, he told me as follows :
line vty o 15
login
password mypass
exit
enable secret mypass
what is the first password for and what is the second password for ?
royalblues Mon, 01/28/2008 - 20:47
THe first password is the telnet or the user level password and the second one is the privilege password
Narayan
majdalani Tue, 01/29/2008 - 03:20
my boss is entering : line vty 0 15 for the telnet command , why then in the show run , it is showing line vty 0 4 ?
Kevin Dorrell Tue, 01/29/2008 - 05:49
vty 0 15 means vty lines 0 to 15 inclusive. Any commants you enter after that will be applied to all 16 of those lines.
However, when you show an IOS configuration, it shows vty lines 0 to 4 seperately from lines 5 to 15, even if the configurations on the two ranges are identical. Not sure why, but it has always done that.
For example, if you do line vty 5 7 and you enter some (different) commands, you will get three blocks in config: line vty 0 4, then line vty 5 7, then line vty 8 15. That is, it groups them together if it can, except that lines vty 0 to 4 are kept seperate from the rest.
It is only cosmetic.
Kevin Dorrell
Luxembourg
