HTTPS thru a PIX on non-standard port
Jan 28th, 2008
We have SSL running on a non standard port that must traverse a PIX.
It's a 525 running 8.0.3
When i attempt to use a browser to access the site: https://x.x.10.51:8021 i get timed out.
When i attempt to telnet x.x.10.51 8021 i get a successful connection.
rcirs001:/>telnet x.x.10.51 8021
Trying...
Connected to x.x.10.51.
Escape character is '^]'.
When i capture or sho conn det i get the same thing:
From the browser:
MDCWSPDEVPIX01# sho capture capout
0 packet captured
0 packet shown
From command line:
2 packets captured
1: 10:47:42.085658 mysource.42361 > x.x.10.51.8021: S 1424688632:1424688632(0) win 16384 <mss 1380>
2: 10:47:42.096644 mysource.42361 > x.x.10.51.8021: . ack 589207218 win 1656
AND
From the browser:
sho conn detail | i x.x.10.51
nothing
From the command line:
TCP outside:mysource/39094 inside:x.x.10.51/8021 flags UB
i understand telnetting to this port doesn't verify the server - i'm just trying to illustrate that there's an issue in how a PIX sees the HTTP protocol over a non standard port.
In the past for other protocols i would have used fixup or inspect for the non-standard ports... but i see no SSL support there.
TIA,
-=Chris
robert.horrigan Thu, 01/31/2008 - 11:33
Looks like your workstation is not even getting to your pix when you go to that weblink. Are you using a proxy server? Is there a router behind the pix that may be blocking that port?
