P bit set to 5 for H323?
Jan 28th, 2008
Our service provider for Metro E point to multipoint said to set the p bit to 5 for H323 on the router. What is the p bit and how is it set on the router?
ivillegas Fri, 02/01/2008 - 09:53
P- Bit is dealt in LSAs in OSPF. External routes are received as Type - 7 LSAs in NSSA router. Type 7 LSAs are confined to only specific area it is received . To further distribute the external Type 7 LSAs are translated into Type 5 LSAs. The P-bit in the type 7 LSA Options field indicates whether the type 7 LSA should be translated. Only those LSAs with the P-bit set are translated into Type 5 LSAs so that the external route can be spread to other areas.
