Caller ID - Calling Name
Answered Question
Environment:
Call Manager 5.1
MGCP gateways
AT&T local PRIs
Qwest LD PRIs
Phones are a mix of 7941s, 61s and 70s.
Will provide more environment info if needed.
Issue: We're able to see calling number just fine but not able to see calling name. I've checked with the AT&T telco and they've verified calling name is on our circuits. Getting confirmation from our LD provider, but they're initially saying calling name is not support on LD PRI circuits. Either way, my DID is on the AT&T circuit and all I get is number, not name. Any configuration that needs to be done for us to see it?
Correct Answer by paolo bevilacqua about 9 years 5 months ago
The exact format depends by the switch. You can see a display IE or a complicated "networking extension". The CM however understand them all.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 01/28/2008 - 08:56
  • Hall of Fame,
    Founding Member
First of all enable "debug isdn q931" and "term mon", and check what you're getting actually.
If name is not there, there is nothing that you can do to have it appear, as it's all in the hands of the telcos.
Ran my debug and placed a test call and below is what I have. So basically what you're saying is if I'm not even seeing a "Calling Name" field, then the telco isn't sending it? Shouldn't I at least a "Calling Name" field that's blank??
Jan 28 17:02:37.951: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x3948
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838E
Exclusive, Channel 14
Calling Party Number i = 0x2181, '312735xxxx'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '1312267xxxx'
Plan:Unknown, Type:Unknown
Jan 28 17:02:38.215: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xB948
Jan 28 17:02:39.615: ISDN Se0/1/0:23 Q931: RX <- ALERTING pd = 8 callref = 0xB948
Progress Ind i = 0x8488 - In-band info or appropriate now available
Jan 28 17:02:40.191: ISDN Se0/1/0:23 Q931: RX <- CONNECT pd = 8 callref = 0xB947
Progress Ind i = 0x8482 - Destination address is non-ISDN
Jan 28 17:02:40.195: ISDN Se0/1/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x3947
Jan 28 17:02:40.647: ISDN Se0/1/0:23 Q931: RX <- CONNECT pd = 8 callref = 0xB948
Jan 28 17:02:40.651: ISDN Se0/1/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x3948
Jan 28 17:02:40.667: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x3948
Cause i = 0x8090 - Normal call clearing
Jan 28 17:02:40.715: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0xB948
Jan 28 17:02:40.731: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x3948
Jan 28 17:02:40.839: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8 callref = 0x297E
paolo bevilacqua Mon, 01/28/2008 - 09:38
  • Hall of Fame,
    Founding Member
Correct, you are not given a name at all.
And is not mandatory to have a "display IE" for the name, to the contrary it would be strange to have it and be blank.
Once telco will start sending a name, it will appear on the phones.
Correct Answer
paolo bevilacqua Mon, 01/28/2008 - 09:53
  • Hall of Fame,
    Founding Member
michaethompson Mon, 01/28/2008 - 11:23
What PRI protocol are you using? NI2 is the norm that will support CID w/ Name. I don't believe DMS100 (NI1) will support it.
