PRI inbound calls problem
Jan 28th, 2008
Hi !
I am getting the following debug output on my MGCP gateway when I want to make an inbound call. The outbound call works fine. There is 910 extension. Any ideas?
thanks,
KO08_2812(config-if)#
*Jan 28 17:13:10.684: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00A7
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x80, '0913885165'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '910'
*Jan 28 17:13:10.692: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x80A7
Cause i = 0x8081 - Unallocated/unassigned number
Brandon Buffin Mon, 01/28/2008 - 10:08
  • Purple, 4500 points or more
Make sure the gateway has a calling search space with access to the partition assigned to DN 910.
Brandon
Brandon Buffin Mon, 01/28/2008 - 11:05
Does the call hit a translation pattern? Is 910 a DN assigned to a physical phone?
Brandon
goranpilat Mon, 01/28/2008 - 11:26
Hi!¨
910 is DN of the physical phone. Phone is in the same CSS as the gateway...
michaethompson Mon, 01/28/2008 - 11:35
what partition is the Phone DN in, what partition is the GW in, and what CSS is applied to each?
also, can you give a list of partitions that are in the CSS applied to each device.
michaethompson Mon, 01/28/2008 - 11:19
I would assume that no CSS is applied to the Gateway for inbound calls. Verify that the CSS is applied and that the CSS has access to the partition containing 910.
goranpilat Thu, 01/31/2008 - 05:41
Hi all!
Thanks for you answers and suggestions. The thing was that below the inbound calls I had AAR calling search space enabled and filled out, so that was the problem. It stayed enabled after all possible combinations were tried out.
regards,
Goran Pilat
