Question about aironet 1400 bridge
Jan 28th, 2008
We are currently trying to set up a link
across the street using 2 bridges. My concern is more of a mounting one and what needs to be visible for the link to work
We are 13 stories up ..and the building across the street is 11 stories up...
We have purches the 9.5 dbi sector antenna. Can I keep the Bridge itself
on the inside and just mounth the antenna
on the outside? While reading the doc, it appeared that the Bridge itself had an antenna
rob.huffman Mon, 01/28/2008 - 16:04
Hi Richard,
The 1400 can be ordered in two models as shown below (with either one the Bridge itself will be mounted outdoors);
Cisco Aironet 1400 Series Bridge with 22.5 dBi Antenna
The Cisco Aironet 1400 Series Wireless Bridge features an 802.11a 5.8 GHz radio, which supports data rates up to 54 Mbps. With this option, a 22.5 dBi patch array antenna is integrated into the ruggedized enclosure
Cisco Aironet 1400 Series Wireless Bridge with Captured Antenna
Product Number
AIR-BR1410A-A-K9
Cisco Aironet 1400 Series Wireless Bridge with N-Type Connector
A connectorized version provides professional installers with an N-Type connector that allows the deployment of the root nodes of point-to-multipoint networks with omni-directional or sector antennas, or of high-gain dish antennas for longer links (Table 2).
Table 2 Cisco Aironet 1400 Series Wireless Bridge with N-Type Connector
Product Number
AIR-BR1410A-A-K9-N
http://www.cisco.com/en/US/products/hw/wireless/ps5279/prod_technical_reference09186a0080184933.html
Quick Start Guide Cisco Aironet 1400 Series Wireless Bridge
http://www.cisco.com/en/US/docs/wireless/bridge/1400/quick/guide/br1410qs.html
The 9.5 Sector Antenna is used for Point to Multi-Point Links;
1400 With 9.5 Sector;
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/14sect.html
Hope this helps!
Rob
