Brooktrout Fax Card
paolo bevilacqua Mon, 01/28/2008 - 10:55
  • Hall of Fame,
    Founding Member
You have a combo card:
http://www.dialogic.com/products/tdm_boards/media_processing/docs/TR1034.pdf
It has 2 loop start ports (used for outgoing and incoming fax) and 2 DID ports (used for incoming only, connecting to analog DID service).
The router interfaces with FXS to card's "loop start" ports, and with E&M, or possibly FXO to DID ports.
Note, there is no cisco "published" configuration for the router to send DID out of an E&M port, that is, to emulate analog DID service by telco.
Actually, I think it can be done, as E&M is very flexible, but not having the hardware, I cannot prove it.
pcameron Tue, 01/29/2008 - 05:00
  • Cisco Employee,
We have made these cards work with FXS ports on the router in the past.
The fax cards generally need the FXS port to send digits to the card so it selects the correct fax 'mailbox'.
In reality, the FXS ports aren't supposed to function as 'Direct Outward Dial', but you can get around this by using the forward digits command.
The cards seem to take a moment to be ready to accept digits, so a delay is needed before the digits are sent out.
To make this work properly, you have to use H323 mode and use a config described below.
As an example, assume you want to send the digits '1500' to the fax card. The dial peer would look like this -
dial-peer voice 1000 pots
destination-pattern 1500
port 0/1/0
forward-digits all
prefix ,,,, <--- this adds a delay of 1 second before the main digit string is sent out the port
paolo bevilacqua Tue, 02/05/2008 - 14:19
  • Hall of Fame,
    Founding Member
No, you must have different model, the one mentioned above is only analog.
