Session reset for appilcation
Jan 28th, 2008
Hi there i have an application in my DMZ wich connects the my server in on the local lan. We use a pix 515E. The thing is that from time to time the connection to the server on the lan is reset. the from the application i have to try 3 times before the connects gets up again. het is what is see in the log of the pix
Any suggestions how to fix this?
Jan 28 14:25:41 SRT: %PIX-6-302013: Built inbound TCP connection 776121 for outside: ( to inside: (
Jan 28 14:25:41 SRT: %PIX-6-302014: Teardown TCP connection 776121 for outside: to inside: duration 0:00:01 bytes 326 TCP FINs
Overall Rating: 4 (1 ratings)
greg-bnets Tue, 01/29/2008 - 06:48
Hi juarez,
Thanks for your reply. Do you know by any chance what can cause on of the ends to send a FIN flag in the packet. Are there some reasons to that?
