Deleted a subscriber a long time ago, now rehired her.
Answered Question
Jan 28th, 2008
  • Silver, 250 points or more
Can't import her because there are Unity attibutes in ad/exchange still and can not see here in the list.
Problem is I need to know what attributes to take out of adsi edit cause I can not use bunny killer or gsm.
rlp. really urgent. thanks.
Correct Answer by Ginger Dillon about 9 years 5 months ago
Hey Randy -
Using ADSIEdit on the Unity server. You will need to provide credentials that have access to update the user account schema, drill down to the container, domain and OU that holds the user. Right-click on the user and select Properties. Select which properties to view - Both. Select a property to view: the attributes you are looking for are ciscoEcsbu**** and select Clear for each attribute named as such.
Ginger
Overall Rating: 5 (1 ratings)
Tommer Catlin Mon, 01/28/2008 - 12:08
  • Green, 3000 points or more
Did you try the Global Subscriber tool. If she shows up in there, you can use it to delete her also.
Correct Answer
Ginger Dillon Mon, 01/28/2008 - 14:40
  • Blue, 1500 points or more
Hey Randy -
Ginger
ranpierce Mon, 01/28/2008 - 14:50
Thanks Ginger I had did that but before I posted. I guess I had to wait for replication.
Your post was very informative. Thanks again.
rlp
Ginger Dillon Mon, 01/28/2008 - 14:53
Hi -
Cool ... Glad to help!
Sincerely, Ginger
