OSPF and 3660/2924XL
Jan 28th, 2008
  • Bronze, 100 points or more
My 3660 is not populating the routing table:
3660 on 12.4.15T2 with 2 FA interface:
10.0.26.100 on FA0/1
10.0.126.1 on FA2/0
I have router ospf 1 with A0 turned on for both interface and confirm with sh ip ospf interface. C6k-Core has full OSPF routing table and I am trying to neighbor up with the c6k-Core.
3660--2924XL---C6k(Access Switch)--C6k(Core Switch)
I can ping the local VLAN26 (10.0.26.x/24) so able to ping/telnet to 2924 and C6k-Core
2924 relevant configs:
Port facing 3660:
switchport access vlan 26
spanning-tree portfast
Port facing C6k-Edge:
switchport multi vlan 26
switchport mode multi
C6k-Edge Relevant configs:
switchport
switchport mode access
Don't think I need to provide c6k-edge to c6k-core as it is working fine for other parts of the network
Edison Ortiz Mon, 01/28/2008 - 12:34
  • Hall of Fame,
    Founding Member
Please post show ip ospf interface bri from both OSPF speaking devices.
__
Edison.
aamercado Mon, 01/28/2008 - 14:24
3660 - Don't worry about Fa 0/1 as I don't have anything attach. I am only concern with F2/0. On the 3660, I was able to telnet to the C6k-core and run the commands
R-WAAS-WAE-CA#sh ip ospf int brie
Interface PID Area IP Address/Mask Cost State Nbrs F/C
Fa0/1 1 0 10.0.126.1/24 1 DOWN 0/0
Fa2/0 1 0 10.0.26.100/24 1 DR 0/0
On the C6k-core
core1#sh ip ospf inter brief
Vl26 1 0 10.0.26.2/24 1 DR 0/0
Vl78 1 0 10.0.78.2/24 1 DR 0/0
Vl68 1 0 10.0.68.2/24 1 DR 0/0
Vl19 1 0 10.0.19.2/24 1 DR 0/0
Vl18 1 0 10.0.18.2/24 1 DR 0/0
Vl16 1 0 10.0.16.2/24 1 DR 0/0
Vl13 1 0 10.0.13.2/24 1 DR 0/0
Vl38 1 0 10.0.38.2/24 1 DR 0/0
Vl33 1 0 10.0.33.2/24 1 DR 0/0
Vl48 1 0 10.0.48.2/24 1 DR 0/0
Vl43 1 0 10.0.43.2/24 1 DR 0/0
Vl53 1 0 10.0.53.2/24 1 DR 0/0
Vl59 1 0 10.0.59.2/24 1 DR 0/0
Vl58 1 0 10.0.58.2/24 1 DR 0/0
Vl56 1 0 10.0.56.2/24 1 DR 0/0
Lo0 1 0 1.1.1.1/32 100 LOOP 0/0
Vl200 1 0 10.0.200.2/24 1 DR 0/0
Vl199 1 0 10.0.99.254/24 1 DR 0/0
Vl150 1 0 10.0.150.2/24 1 DR 0/0
Vl70 1 0 10.0.70.254/24 1 DR 0/0
Vl60 1 0 10.0.60.254/24 1 DR 0/0
Vl34 1 0 10.0.34.2/24 1 DR 0/0
Vl32 1 0 10.0.32.2/24 1 DR 0/0
Vl28 1 0 10.0.28.2/22 1 DR 0/0
Vl27 1 0 10.0.27.254/24 1 DR 0/0
Vl24 1 0 10.0.24.2/23 1 DR 0/0
Vl23 1 0 10.0.23.2/24 1 DR 0/0
Vl22 1 0 10.0.22.2/24 1 DR 0/0
Vl21 1 0 10.0.21.2/24 1 DR 0/0
Vl20 1 0 10.0.20.2/24 1 DR 0/0
Vl2 1 0 10.1.254.2/16 1 DROTH 2/4
Edison Ortiz Mon, 01/28/2008 - 15:40
  • Hall of Fame,
    Founding Member
Both are set to DR on the same LAN so they haven't seen each other.
Can you change the
to
Can you connect the 3660 directly to the Cat6k Edge ?
OSPF relies on multicast, are you doing any multicast filtering ?
glen.grant Mon, 01/28/2008 - 16:01
  • Purple, 4500 points or more
What is the function of the 2924 , seems starnge haveing it in the middle of a core dist link . Maybe you can post a "show ip ospf interface" for each side of the link .
