Hi, depending on the IOS and type of unit you have you could very well support flow control on your trunk links. Issue the "show interface capabilities" command and the switch will list the abilities of each port for you. HTH
sib-124-sw1#show interface capabilities
FastEthernet0/1
Model: WS-C3550-24-PWR
Type: 10/100BaseTX
Speed: 10,100,auto
Duplex: half,full,auto
Trunk encap. type: 802.1Q,ISL
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QOS scheduling: rx-(1q0t),tx-(4q0t),tx-(1p3q0t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: yes
SPAN: source/destination
PortSecure: yes
Dot1x: yes
FastEthernet0/2
Type: 10/100BaseTX
Speed: 10,100,auto
--More--
erikhoehne Mon, 01/28/2008 - 18:46
I'm running CatOS. The port shows to have the capabilities. However, I was concerned it might give me an error when trying to enable flow control since the port is a dot1q trunk. I can't find any info on Cisco's website saying it isn't possible, so I'm thinking it will work.
I'll give it a try during our next maintenance window.
Thanks for the reply!
Later,
Erik
erikhoehne Tue, 01/29/2008 - 12:46
Good Afternoon William,
The main reason I was thinking the switch might give me an error; even though the switch port shows to have flow control capabilities, is trunk links act a bit different. In the past, the switch has spit out an error at me when trying to enable certain protocols on the trunk links; even though the switch port shows it's capable.
Thanks for the tips buddy;-)
Later,
Erik
