VIC-2FXO-M2 - Caller ID, CLID & CME 3.3
Jan 28th, 2008
Hi there, been racking my brains trying to get Caller ID working with the VIC-2FXO-M2. Installed in a 1760, have pretty much tried every combination of options in the voice-port 2/1 config (see below pasted section). I can't think what else I need to do get get this working. If anyone can cast any light on the subject matter it would be appreciated. VMT
voice-port 2/1
input gain 8
output attenuation -1
no comfort-noise
cptone GB
timing sup-disconnect 85
connection plar opx 3007
impedance complex1
caller-id alerting dsp-pre-allocate
Paolo Bevilacqua Mon, 01/28/2008 - 12:58
Hi, if you connect an analog phone, does it work ?
Also please state exact IOS you're using.
Bananaskin Mon, 01/28/2008 - 13:05
Sorry, analog phone on the FXO port?
As for the ISO version: 12.3.14T7(ED)
Paolo Bevilacqua Mon, 01/28/2008 - 13:07
You connect a phone with clid display to your wall jack and check that clid is displayed.
About IOS, if you ram/flash allows, better would be 12.4(3j).
Bananaskin Mon, 01/28/2008 - 13:26
Sorry, took my eye off the ball. Yes the line does receive CLID information and likewise the GSM gateway sends the CLID info as well. As for 12.4(3j) not enough ram to comfortably run that version.
