Output of sh int fa0/0 - throttle question
Jan 28th, 2008
Is the throttle value above acceptable? The complaint is lagging internet and our network monitor does show them peaking at times...
Rtr has been up about 6 months...
Input queue: 0/75/50/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1045000 bits/sec, 156 packets/sec
5 minute output rate 337000 bits/sec, 139 packets/sec
1009124324 packets input, 3307816162 bytes
Received 0 broadcasts, 0 runts, 0 giants, 48 throttles
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 01/28/2008 - 14:23
Hi, your throttles value is minuscule compared to total input. Likely router has no fault, check your bandwidth usage, P2P, how yous ISP is doing, etc.
