Too much traffic in the network
Jan 28th, 2008
Hi.. 2 situations !
I made a test with a traffic generator.. the target was a IP Phone 7912... and after a few sec, it lost connection to CM..
- is there anyway of protecting IP Phones from this kind of 'attack' ?
- what is the best solution when you have a 3650 (gigabit switch) and PC with Giga ethernet NIC.. and there is a phone between them with 100mbps switch ?! did anyone faced this situation ?
Thanks.
Andrei.
Overall Rating: 3 (1 ratings)
pcameron Tue, 01/29/2008 - 04:39
The 7912 handsets have some limitations in handling high traffic rates. Refer to the attached PDF for more background and suggestions on how to mitigate this.
