Three tier architecture configuration
Jan 28th, 2008
We wanted to configure the network attached.
We wanted to know how best we can configure access layer switches, distribution switches & Core switches.
Access switch is 3750 PoE,distribution is 4506 & Core is 6513
We are planning to use static routing within the campus & OSPF across WAN.
If you have any configuration examples it would have been very helpful.
Thanks.
Rgds.,
Sack
dnewell24 Tue, 01/29/2008 - 05:17
  • Bronze, 100 points or more
Arul's suggestion is right on. To add I suggest looking at the High Availability Campus Network Design-Routed Access Layer using EIGRP or OSPF. I've always thouhgt this design provides the quickest convergence, fault-tolerance, and most efficient load-sharing for a campus network.
