ACL permitting DHCP requests
Jan 28th, 2008
Hope someone can help me on this,
having the following configuration, DHCP requests doesn't seems to work properly. Not sure if I've missed anything
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.215.12.129 255.255.255.128
ip access-group CLC_ACL in
ip helper-address 172.22.25.5
ip access-list extended CLC_ACL
permit udp 10.215.12.128 0.0.0.127 host 172.22.25.5 eq bootps
permit udp 10.215.12.128 0.0.0.127 host 172.22.25.5 eq bootpc
permit udp any any eq bootps
permit udp any any eq bootpc
I do see some matches on both entries that has the bootps, but the PCs does not seems to be grabbing any IP
johnd2310 Tue, 01/29/2008 - 00:58
hi,
If you remove the access list and just use the helper address, does the PC grab an ip address?
John
