unable to access the secondary WISM from the diffrent VLAN
Jan 28th, 2008
We have got 2 WISM,We are able to access the primary WISM from the diffrent VLAN through GUI mode,But we are not able to access the secondary WISM from diffrent VLAN through GUI mode.We are able to access the secondary WISM from WISM management VLAN.I am attaching the WISM management config below.
Core1
VLAN 4 ---- Wism Management
ip address 172.16.10.2/24
HSRP 172.16.10.1
Primary WISM IP address 172.16.10.4
Core2
ip address 172.16.10.3/24
HSRP 172.16.10.1
Secondary WISM IP address 172.16.10.5
Can any one get me the solution for this.
Regds
Saji k.s
Anonymous (not verified) Fri, 02/01/2008 - 12:41
Check if the routing from VLAN is enabled . Make sure Management and Ap-Manager interface must be un-tagged for example Vlan 0 when they are on the Native Vlan of the trunk. Remove the tags from the management interface.
Also check if you have Filters created that blocks access to secondary WiSM.
Trending Topics - Security & Network
