Help!Explain the specification of interface
Jan 29th, 2008
Hi,I have a issue about specification of the "show interface vlan ".Could you explain how to calculate the "txload" parameter?
mohammedmahmoud Tue, 01/29/2008 - 01:06
  • Green, 3000 points or more
txload and rxload are calculated as a fraction of 255 (255/255 is completely saturated interface), below is an example (i am using a serial interface, but the logic is the same), from the input (114000 bits/sec) and output rates (323000 bits/sec) and the interface BW (1536 Kbit) we can calculate the txload and the rxload as a ratio:
txload = (255 x output rate) / BW
rxload = (255 x input rate) / BW
sh interfaces Serial0/1
Serial0/1 is up, line protocol is up
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 53/255, rxload 18/255
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
LCP Open
Open: IPCP, CDPCP
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d01h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 45
Queueing strategy: weighted fair
Output queue: 0/1000/64/45 (size/max total/threshold/drops)
Conversations 0/15/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
30 second input rate 114000 bits/sec, 179 packets/sec
30 second output rate 323000 bits/sec, 196 packets/sec
31555996 packets input, 3245722698 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
33659431 packets output, 2683391659 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
BR,
Mohammed Mahmoud.
haijason Tue, 01/29/2008 - 01:12
first,thank you for your reply.
Indeed,I want to know how to calculate the vlan interface's BW.
I think maybe there is difference between the physical interface and the logic interface.
mohammedmahmoud Tue, 01/29/2008 - 01:21
Hi Shan,
VLAN interfaces have a default BW that varies between platforms (for example the old 3512 uses 10000 Kbit, while the 3560 uses 1000000 Kbit, you can always check it via the show interface vlan x), you can manipulate this values via the bandwidth command under the interface (doing this has nothing to do with the physical speed of the interface let it be a physical or a logical interface).
BR,
Mohammed Mahmoud.
haijason Tue, 01/29/2008 - 01:31
sorry, I still have some confusion,can you tell me how to calculate the txload 156/255 ?
___________________________--
Vlan301 is up, line protocol is up
Hardware is EtherSVI, address is 000a.42b3.5800 (bia 000a.42b3.5800)
Description: Link-to-Rcs7513-1
Internet address is 136.31.32.206/30
MTU 4470 bytes, BW 16000 Kbit, DLY 10 usec,
reliability 255/255, txload 156/255, rxload 57/255
Keepalive not supported
Last clearing of "show interface" counters 5w6d
Input queue: 0/75/459/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 19692000 bits/sec, 12601 packets/sec
5 minute output rate 105044000 bits/sec, 14771 packets/sec
L2 Switched: ucast: 37809177 pkt, 4683972361 bytes - mcast: 2232193 pkt, 243322550 bytes
L3 in Switched: ucast: 28623709383 pkt, 17709262524104 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 17400287840 pkt, 7471416775021 bytes mcast: 0 pkt, 0 bytes
31506251466 packets input, 18311607672072 bytes, 0 no buffer
Received 2232195 broadcasts (0 IP multicasts)
0 runts, 0 giants, 1 throttles
23156536686 packets output, 8752425131920 bytes, 0 underruns
0 output errors, 0 interface resets
VDubrovskikh Tue, 01/29/2008 - 03:28
I think ...
txload = (16000Kbit*156)/255 = 9788Kbit per sec
haijason Tue, 01/29/2008 - 06:44
oh..
I think txload should be a fraction, such as
156/255.
And I just want to know how can I calculate the value 156/255?
Thanks.
