ACS database connectivity
Answered Question
Jan 29th, 2008
Dear Sir
I have planned to connect my ACS server to external database (oracle 10g) in order to perform this case would you please let me know how I would be able to connect ACS to oracle. It is considerable to say that I have read some Cisco document about this case but still there is some problem. I would be happy if you let me know your comment.
With best regards
Hamed yazdi
Correct Answer by didyap about 9 years 3 months ago
To connect ACS server to Oracle database click External User Database >Database Config > External ODBC Database and mention the server running Oracle. Following link may help you
http://www.cisco.com/en/US/products/ps8543/prod_troubleshooting_guide_chapter09186a00808e7d1d.html
Overall Rating: 5 (1 ratings)
hamedyazdigss Fri, 02/08/2008 - 11:23
Dear Sir
Billion thanks for your kind reply. Whatever you have mentioned I did, and at the moment my ACS server can connect to my Oracle server but there is another question which I want to create a table which conation username and password of those who want connect to the network via ACS but I do not know which name I should assign to the table and where I should defined to ACS which check the username and password. In other word how should I define to ASC that which table it should check in order to recognise the users has permission or no. I would be happy if you let me know your comment.
With best regards
Hamed yazdi
