01-29-2008 01:47 AM - edited 02-21-2020 03:30 PM
Would you please help me on this:
What is the cheapest Cisco router for a 10-20 employees office environment which supports DMVPN or any other technology in order to maintain a permanent IPSec tunnel, no matter that the service provider to this office allows only dynamic IP address assignment?
I know about the 2801 and 1841, but is it possible to go even lower?
Mladen
Solved! Go to Solution.
01-31-2008 05:33 AM
We use the Cisco 871 ethernet router and have much success with that router using DMVPN.
02-02-2008 07:13 PM
Doing this with 2611's from ebay for $100.
Need to go lower? ;)
http://cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008019d6f7.shtml
01-31-2008 05:33 AM
02-02-2008 12:53 PM
Could you give a bit more details on your setup ? I will also need to design a setup where all members of the meshed vpn have dyn. IP's. I was thinking of using DMVPN in conjunction with Real-time Resolution for IPSec Tunnel Peer, using cisco 877 models.
Hans
02-02-2008 07:13 PM
