Outgoing voice low volume - PRI
Answered Question
Hi there,
I am having an issue with low volume of voice going out, incoming is fine.
I have a 2801 with PRI and a couple of 7911 phones.
I have tried the "output attenuation" command under the voice port, but it did not make any diference, even between -6 or 14. On the other way, "input gain" worked fine.
Could it be the provider (BT) that is normalising the signal?
Correct Answer by Paolo Bevilacqua about 8 years 11 months ago
Hi, please configure:
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
That will eliminate all errors on controller E1 and voice quality should improve.
Overall Rating: 5 (2 ratings)
------------------ show controllers e1 ------------------
E1 0/3/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071009, FPGA: 20, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (651 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
6 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
6 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 4 15 minute intervals):
1 Line Code Violations, 3 Path Code Violations,
37 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
40 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Correct Answer
Paolo Bevilacqua Tue, 01/29/2008 - 04:14
