Pix 6.3(4) upgrade to 7.x
Answered Question
Jan 29th, 2008
I have a pix 515E in failover mode running ver 6.3(4). We want to upgrade to 7.x but do not know which version of 7 to start with. Can anyone tell me the best path to follow. Can I upgrade from 6.3(4) to 7.2 without first upgrading to 7.0.
Rgds
pet
Correct Answer by jojuarez about 9 years 2 months ago
Yes, you can but it is not recommendable. Please upgrade first to 7.0.7 which is the latest one within 7.0 train. Then you can go for 7.2.x
Please bear in mind that there are some commands that have been deprecated from 6.x to 7.x specially on VPN:
http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.html#wp1753758
Overall Rating: 5 (2 ratings)
m.sir Tue, 01/29/2008 - 03:59
  • Gold, 750 points or more
The minimum software version required before performing an upgrade to PIX Version 7.2 is PIX Version 7.0
Check this link for more info
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807c3627.shtml
http://www.cisco.com/en/US/docs/security/pix/pix72/release/notes/pixrn722.html#wp43582
M.
Hope that helps rate if it does
peteruwa Fri, 02/01/2008 - 07:54
Thaks M. I will try that in a couple of weeks and let you know.
Rgds
pet
