Reserving Bandwidth for certain IP range
Jan 29th, 2008
I have two 6509 switches located in two different offices(connected through 40Mbps pipe). And i have to reserve bandwidth of 2Mbps for certain IP range between these offices. how do i accomplish this.
Jon Marshall Tue, 01/29/2008 - 04:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
It does depend on your supervisor and PFC level but if you have a PFC3 card then the 6500 provides something called User Based Rate Limiting. See attached link for more details
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5017.html
Jon
kiran_8095 Tue, 01/29/2008 - 05:04
hi ,
thanks for the information. the actual requirement is to reserve 2mbps bandwidth for the data between Servers located in the locations. can i achieve this using user based rate limiting.
thanks
k
Jon Marshall Tue, 01/29/2008 - 05:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
User based rate limiting is a bit of a misleading term actually as it is based on source and/or destination IP address so yes this should fit your requirements.
Jon
