diro Thu, 01/31/2008 - 02:09
The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, and c1240-k9w7-tar.default for a 1240 series access point.
omar.elmohri Thu, 01/31/2008 - 10:35
As I'm seeing is that it takes about 15 seconds to fire the timeout! are you sure that the file is not copied to the AP ? I didn't tried that before, but I can suggest some ideas:
-can verify of the file is not corrupted
-or try to use another TFTP server! which one you are using?
Regards.
